input variable no read in MathScript node
I'm having a problem with reading an input. The input is a 64 bit real 2-D array of double. I will refer to the attached screenshot. All other inputs, such as "all" (meaning all channels) and "trig" (trigger), I can read, no problem. The problem is I cannot read "chan", which is part of the array "all" (containing all channels), but referenced to a reference channel. If i dispaly the "chan" array in LV I can see it no problem, I can even read the size of it and display it. Why can't I use it in the MathScript node?
