Configuring Traditional DAQ in MAX using set default daq configuration.vi
BorSh
Hello.
I’ve got a problem with Traditional DAQ configuration file loading in MAX. I use .daq file that contains the names of channel. In my application I load this .daq file using Set Default DAQ Configuration.vi before starting to sample the input data us shown in the attached figure (I use 6025E card). When I set up this application on another computer it doesn’t work announcing me about Error 10401 occurred at AI group configuring (The specified device is not a NI product…). That is, it can’t load the configuration from the .daq file. Only after I just open and close MAX in this computer it starts to work. This occurs for ones when I reinstall my application.
I need the application without the need to come to MAX for configuring the channel names.
Thanks for help.
BorSh.
