configuring FPGA compile server
souske
Is it possible to configure FPGA Compile Server in such a way that it would omit the tests at the end of the compiling process?
Regards
souske
QUOTE (souske @ Apr 7 2008, 09:16 AM)
Regards
souske
I don't know of any methods for omiting the tests at the end of the compile process, nor would I want to even if it were possible. The tests ensure that the FPGA code generated is valid from a timing perspective. Using code that didn't pass those tests could produce unpredictable results.
