minority Posted April 9, 2008 Report Posted April 9, 2008 Hi, I'm reading data from a .ini file and want to convert all the data read into strings. The number and order of data types in the .ini file will vary, so I cannot manually program LabVIEW to convert the data into strings and must try to find out what data type was read. So my question is, is there a sort of "istype" function available in LabVIEW. All help very much appreciated, thanks! cheers QUOTE (minority @ Apr 8 2008, 06:55 AM) Hi,I'm reading data from a .ini file and want to convert all the data read into strings. The number and order of data types in the .ini file will vary, so I cannot manually program LabVIEW to convert the data into strings and must try to find out what data type was read. So my question is, is there a sort of "istype" function available in LabVIEW. All help very much appreciated, thanks! cheers Solution found. Was as simple as setting the default value of the Read Key.vi as a string type. Sorry. cheers Quote
