Mission Accomplished! YEAH
Jimbo29
Geez, what a headache. But I got it to work properly. Was able to establish communication via Lab View HMI to a Direct Logic DL230 PLC using the DS Data OPC server (DS data server is included with the direct logic install). For example, I bound six toggle switches (Must be read/write) through the OPC server and to the PLC. The problem I was having at first was simple; I didn't put an END statement in a blank PLC program and I didn't enable the OPC server. So I just made another toggle switch and bound that to the enable bit. Made it true and BOOM it worked. If anyone wants to do the same thing you can message me and I will be more than happy to assist you.
