Biswa Posted May 7, 2008 Report Posted May 7, 2008 Hi there, I have modified the MultiFunction-Sync-In-Out to accept 4 analog ins and 1 analog out but as you can see I always get Error -200288. I have attached the vi along with this message. If one runs Labview in debug mode than anther error 200279 is also visible at the error out port of the Analog Read VI. If this problem is solved, I would like to output a second analog channel with a pulse to mark signal out from the first analog out. Please advise. Cheers, Biswa Quote
