print out problem
hi everybody,
i have a problem again :(
i wrote a program but the time was run down. i could't understand, why??
other problem, i want to print out the "waveform chart". can i do it just push the button. ( example; stop button is stop the program etc..)
pls help me
look forward your reply
take care
hakan...
QUOTE (hakannn @ May 28 2008, 10:57 AM)
Your problem isn't clear by this explanation... please provide more detail?
Check out this example (found by searching the examples in the help section for "printing"):
<LabVIEW>\examples\reports\PrintControlExample.vi
Here is a simplified example that may be more clear on what is going on:
post-3266-1211999520.png?width=400
There are other ways to do this, but this is probably the easiest way.
my problem, the chart isn't make progress in the time.
if i run the program without "formula", everything is good but when i added the formula then the time was run down. the time isn't make progress. i think problem is "formula" but i have to use it bc i want to change strenght's value. can i do other way??
could i understand??
thanks
QUOTE (orko @ May 28 2008, 07:32 PM)
now, i can't try it bc i'm at home. when i come to the school ( later 9 hours ) i'll try it. i hope it'll solve the problem.
thanks for your help.
QUOTE (orko @ May 28 2008, 08:50 PM)
i looked this examples ( LabVIEW>\examples\reports\PrintControlExample.vi ) all day but i couldn't understand. bc i'm new Labview :(
but i'll try your other way. i hope i'll manage it :)
hi everybody,
now, my program is running :)
but it's print out the all program stop. but i want to save the chart and if i want the print out the chart i can push the button on the front panel and i'll print the chart.
anybody help me??
thanks for everything
hakan
