vestman Posted June 14, 2008 Report Posted June 14, 2008 Hi Is it possible to access a Single-Process Shared Variable using DataSocket? When I try it DataSocketOpen throws Error 1184 (Path not found, FTP login incorrect, or no FTP write permission.) If I change the variable to Network-Published it works fine. /Emil Quote
vestman Posted June 17, 2008 Author Report Posted June 17, 2008 I still haven't found a way to read/write Single-Process Variables except putting a Shared Variable structure on the block diagram. Is this really the only possible way? Quote
David Wisti Posted June 17, 2008 Report Posted June 17, 2008 QUOTE (vestman @ Jun 16 2008, 05:08 AM) I still haven't found a way to read/write Single-Process Variables except putting a Shared Variable structure on the block diagram. Is this really the only possible way? Single-Process Shared Variables are just global variables wrapped in an XNode. You can not access globals with datasocket. Quote
