irpotential Posted June 18, 2008 Report Posted June 18, 2008 I've got my program working 95% with the help of those in the lab I work in and finding vi's here (you may recognize the boxcar algorithm, thanks to whoever it was that posted that). However, I cannot figure out how to change some of the labels in the text file that my program is outputting. I would like to change the units and the column descriptions for each column of data in the output file. The vi was generated using labview 8.5 professional development system. Quote
Phil Duncan Posted June 19, 2008 Report Posted June 19, 2008 I have had a look at this. Normally the quickest way to "name" the data in a wire is to connect it to/from a control/indicator. Then the data inherits the name from the control/indicator label. I could not see an easy way to achieve this in your example. That is not to say that suach a method exists. However upon digging quite deep within the Write LVM express vi, I managed to find a few useful vis that allow you to tap into the details of dymanic signals. I have attached a modified vi for you. Cheers & Beers :thumbup: :beer: Download File:post-4848-1213771823.vi Quote
irpotential Posted June 19, 2008 Author Report Posted June 19, 2008 QUOTE (Phil Duncan @ Jun 18 2008, 02:51 AM) I have had a look at this. Normally the quickest way to "name" the data in a wire is to connect it to/from a control/indicator. Then the data inherits the name from the control/indicator label. I could not see an easy way to achieve this in your example. That is not to say that suach a method exists.However upon digging quite deep within the Write LVM express vi, I managed to find a few useful vis that allow you to tap into the details of dymanic signals. I have attached a modified vi for you. Cheers & Beers :thumbup: :beer: http://lavag.org/old_files/post-4848-1213771823.vi'>Download File:post-4848-1213771823.vi Thanks for the help. Why is it that a control/indicator won't name the data in my program? I'm having a very hard time visualizing and understanding what labview does with it's data and how you manipulate it. Quote
JasonXCX Posted June 20, 2008 Report Posted June 20, 2008 A small point of interest: You can import the file in Star Office but in France if you keep the default setting ; number are imported as text . The reason? the decimal point : in France 12,6 = 1*10^1+2*10^0+6*10^-1 = 12.6 in USA . So my Star Office (France) understand 12.6 as a text. After some time I find : you have only to change the importation setting the column is not "Standard" but US. After that everything fine. QUOTE (irpotential @ Jun 18 2008, 03:05 PM) Thanks for the help. Why is it that a control/indicator won't name the data in my program? I'm having a very hard time visualizing and understanding what labview does with it's data and how you manipulate it. It is better with the capture od the screen A small point of interest: You can import the file in Star Office but in France if you keep the default setting ; number are imported as text . The reason? the decimal point : in France 12,6 = 1*10^1+2*10^0+6*10^-1 = 12.6 in USA . So my Star Office (France) understand 12.6 as a text. After some time I find : you have only to change the importation setting the column is not "Standard" but US. After that everything fine. Quote
