lampersberger Posted June 24, 2008 Report Posted June 24, 2008 Hi there, Got some stupid problem (I locked myself out from my VI), which I´m trying to fix for some time already. But nothing works! What I wanted to do: - Make a program, which starts automaticly on a double-click in Windows(-Explorer). And when the user presses the "END" button it closes. What I did: - I set the front panel appearance as "Dialog" in the VI settings (stops or interupts by the user are no allowed). - I put an "END-Labview"-box at the end of the program (that it closes, when the "END" button is pressed). What the program does: - Exactly what it should (opens, runs and finishes after "END"). - But I don´t get into the block diagram anymore to make changes. - I tryed to stop it by provoking errors, but it just crashes. - Also breaks in SubVIs don´t let me interupt the main VI. - I tried hot keys (Ctrl+., Ctrl+E, Ctrl+C etc.). - I tried starting it in Windows-Explorer holding down Shift, Alt or Ctrl (this works with some other application). Question: - Is there some way to get into the block diagram, or is it lost and I can redo the whole VI??? Thanks for any helping replay in advance! Quote
shoneill Posted June 24, 2008 Report Posted June 24, 2008 This used to work.... Drop the vi as a sub-vi in an untitled block diagram (Put some broken code in if neccessary). Then double click it to open it without running it. Shane. Quote
lampersberger Posted June 25, 2008 Author Report Posted June 25, 2008 Thanks, it worked. Got my VI back to make changes! Quote
shoneill Posted June 25, 2008 Report Posted June 25, 2008 QUOTE (lampersberger @ Jun 24 2008, 09:50 AM) Thanks, it worked. Got my VI back to make changes! Glad to have been able to help. Shane. Quote
