mjagani Posted July 8, 2008 Report Posted July 8, 2008 Hello all. I'm been using LabView for 2 weeks so I'm relatively new to this. This VI is designed to control a infrared heater. It is supposed to compare the actual temperature to the set temperature, hold that set temperature for a X amount of minutes, by outputting voltage to the controller of the infrared heater. I'm not sure if the timing for this VI is correct, so can someone take a look at it and let me know? Also, help for any part of this VI is needed so let me know if there's a better way to do something. Thanks a lot. Edit: Let me know if you need me to explain something I did on the VI. Quote
