Annotations
Hello,
I'm working an aplication, which includes graph. On this graph I want to set annotations, but every time I close program annotations dissapear.
Is there anny way to save those annotations?
I must say I'm not a rookie in LV, but I have never used annotations.
thnx
Rok
QUOTE (Nighthunter @ Jul 15 2008, 01:31 PM)
  Quote
Annotations are just a property of the graph (an array of clusters). You can save them but you have to write the code to do it yourself (there is no NI built in way to save/recall annotations).
You can right click on the graph and select Data Operations > Make Current Value Default. Then save the VI.
This will also save any data stored in the graph. So you may want to select Data Operations > Clear Graph first.
-James
