tekfis Posted July 29, 2008 Report Posted July 29, 2008 hi All, I'm now working on modelling anaerobic digestion model using LabVIEW 8.2.1 and I have to re-program that model from simulink-Matlab. I have to create the VI model using the simulation translator (with a lot of data type fixing using index array and build array, is it normal?). I'll attach the result using simulation translator. when the compiler says ok, i can't run the simulation. the error message send this: Error−2318 The dimensions of the parameter vectors of this function do not match. After a while, the system always crash and needed to close everytime I run this model. The main system's VI is AD. The time is running out for me, anybody please help me on this problem. Thanks In Advance, Asep Quote
