ekabudiono Posted September 9, 2008 Report Posted September 9, 2008 Hello, I am new in LabView. I design the "microcontroller based module" to connect with LabView. And then I wrote the OPC Server for the module. Now I can take any I/O status in microcontroller module from its OPC Server and send to LabView panel using the NI DataSocket. The question is: Is it RELIABLE ENOUGH in any application compared with 'normal' bus, since I did not use bus like modbus etc in acquiring the I/O status ??? So I take the real I/O status not using the bus but using the I/O OPC Server. Please give assistance, thank you very much Regards. Eka Quote
