Center dialog on caller
Here is an example of how to center your dialog boxes on the front panel of your application. This uses a set of utility VIs I created that will allow you to specify the VI to center on. If you do not specify a VI, then it will search the call chain for the nearest caller who has an open front panel. If there are no VIs in the call chain open, then it will center it on the screen.
I use this a lot in my applications. I hope you find it useful as well.
-John
Download File:post-2411-1221526151.zip
