MichaDu Posted October 10, 2008 Report Share Posted October 10, 2008 Hi, I'm using a cRIO system with analog input module 9205. To get correct voltage values, I have to read the calibration values. There are examples to do this only in RT VI, but not inside the FPGA VI. I only want to process data inside the FPGA VI without RT (reading voltage, processing and writing to AO module). Has anybody done this before? Or can I neglect the calibration without getting large error? Quote Link to comment
viSci Posted October 10, 2008 Report Share Posted October 10, 2008 If you use the fixed point acquisition then calibration is included in the measurements. Quote Link to comment
MichaDu Posted October 15, 2008 Author Report Share Posted October 15, 2008 Hi Michael, thanks for your help! That means I do not have to take care about any calibration parameters, just read out fixed-point values and work with them? That would make my application much easier! While I prefer working with physical integer data than fixed-point data, I programmed some module specific VIs to convert FXP-V to I16-mV and FXP-A to I16-µA. This makes it more easy again! Kind regards Quote Link to comment
