Michael Hill Posted November 5, 2008 Report Posted November 5, 2008 I am creating a new DAQ system for my department, and we want the ability to use some files from our old DAQ system. However, I am unable to view the diagram of a certain VI we have that's rather important in the process so I can update it. However, the VI appears to be locked with no password. However, I can't simply click unlock as the whole window is "greyed" out. What can be done? Also note, I am using LabVIEW 5.0 on Solaris. Quote
Darren Posted November 7, 2008 Report Posted November 7, 2008 Your VI was saved with its block diagram removed. You need to find out if there's a backup of the VI anywhere that still has the diagram...otherwise, you're stuck with it. Also note that you can't use a diagram-less VI in any LabVIEW version other than the one it was last saved in (i.e. the version used to remove its diagram). Good luck, -D Quote
