snapy050 Posted November 18, 2008 Report Share Posted November 18, 2008 Hi all! I am a student using evaluation version of NI Vision assistant 8.6. I have a script file that i want to convert to VI. As you know we cannot do it on a evaluation version. I neither can afford the package right now. Please help me convert the file to VI and C code. Please mail me on <email address removed by moderator> Will be very thankful if some one generously helps. Regards, Snapy Quote Link to comment
snapy050 Posted November 18, 2008 Author Report Share Posted November 18, 2008 Hi all! I am a student using evaluation version of NI Vision assistant 8.6. I have a script file that i want to convert to VI. As you know we cannot do it on a evaluation version. I neither can afford the package right now. Please help me convert the file to VI and C code. Please mail me on snapy050@gmail.com Will be very thankful if some one generously helps. Regards, Snapy Quote Link to comment
crelf Posted November 18, 2008 Report Share Posted November 18, 2008 Maybe contact NI directly - they might be able to help you out. Quote Link to comment
Minh Pham Posted November 19, 2008 Report Share Posted November 19, 2008 Give NI a call and an application engineer might help you out. If not, i believe whatevar you can do in Vision Assistant you can do it in LabVIEW so might be a good thing to learn how to develop application in LabVIEW. I used to be a student and I did all the vision stuff in LabVIEW, not Vision Assistant. You will understand the problem much better when you work in the lower layer, it's a part of studying, isnt it? Good luck. Quote Link to comment
