In Place Structure
EJW
This is probably not the right way of using inplace element. It is design for working with element/structure which has the same size at both the input and output. Operations such as modifying data element within array, swap data between array indexies...without creating an extra memory
buffer, hence performance is improved.
Building a new array based on the data from the inplace element (IPE) input node will not help as you are increasing the size of the IPE output, as the result, LV still has to organize buffer for the operation described.
Link to post
QUOTE (Minh Pham @ Nov 20 2008, 06:52 PM)
Actually, i am replacing the third element with new data, same size. I keep the first two indexes and input a new third array to replace the original.
Link to post
QUOTE (EJW @ Nov 21 2008, 09:43 AM)
I think the problem is that you're using the Build Array to create a completely new array - not working on the old one. Why not use the Replace Subset function?
Link to post
QUOTE (EJW @ Nov 21 2008, 06:43 AM)
asbo has it right. You aren't telling the LV compiler any more than you were telling us, and we didn't understand either. You have to throw it a bone.
Put another way, you may know that the array will stay the same size, but the LabVIEW compiler has to generate code which will always work, no matter what you may have dropped into the local variable at some point.
Once you do the right thing and use replace subset, you don't need the inplace compiler hint anymore, because the Replace function always operates inplace.
Link to post
