h4xh4x Posted December 4, 2008 Report Posted December 4, 2008 Hi I've made an ActiceX container with flash in a VI. The flash-object is searching for a Variable called "xkoordinat". Is it possible to "generate" the variable in LabView and pass it on to the flash-object? Thanks in advance Quote
kaarthik_kaarthik Posted December 12, 2008 Report Posted December 12, 2008 You need to have the variable or a text box declared in the .flv before publishing the .swf file. You cannot dynamicaly create a variable and pass it on to the flash. Quote
marcosmantis Posted March 17, 2009 Report Posted March 17, 2009 QUOTE (h4xh4x @ Dec 3 2008, 01:31 PM) Quote HiI've made an ActiceX container with flash in a VI. The flash-object is searching for a Variable called "xkoordinat". Is it possible to "generate" the variable in LabView and pass it on to the flash-object? Thanks in advance If you are saying that this works. can you post the actionscript source? thks Quote
