Search for a best way to realzie data exchange in lv8.6+DSC
zyh7148
Hi
we will build a large distribution control system. Before, we used share variable to complete data exchange between different PCs. But, because of bugs in labview , there are some problems by this method. so, I don't know whether there are better way to achieve this task. Please give me some helps! Thanks.
QUOTE (crelf @ Jan 4 2009, 04:32 AM)
Tell us about the bugs.
So, we use share variable binding and read/write by datasocket. When the number of share variable is a few, simultaneous reading/writing share variable is no problem. But when the number is a great many, there are some error report. If use serial reading/writing, it is no problem. I don't know why. So, I want to find a better way. Thanks!
QUOTE (zyh7148 @ Jan 4 2009, 05:30 AM)
...when the number is a great many, there are some error report.
If the error is the only problem that you have with that method, then I suggest you find out what the problem is and, if it can be fixed, continue with that method. What's in the "error report"? Have you talked to NI about it?
