PeterB Posted January 12, 2009 Report Posted January 12, 2009 This post is to follow up from here where I reported that NIScanEngine\nilvce.dll couldn't be found during a build I was attempting. It was a non fatal error as the exe still built. NI gave me a solution by suppyling me with the missing directory and files (zipped up) which you install to here C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\NIScanEngine\ Unless NI have posted these files on their website, please contact ni.com/ask and ask for the application engineer to send you a copy of NIScanEngine.zip regards Peter Quote
gleichman Posted January 12, 2009 Report Posted January 12, 2009 I had the same error, but it was fatal for my build. Same solution as yours. QUOTE (PeterB @ Jan 11 2009, 06:55 PM) Quote This post is to follow up from http://forums.lavag.org/-t11544.html&view=findpost&p=55706' target="_blank">here where I reported that NIScanEngine\nilvce.dll couldn't be found during a build I was attempting. It was a non fatal error as the exe still built.NI gave me a solution by suppyling me with the missing directory and files (zipped up) which you install to here C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\NIScanEngine\ Unless NI have posted these files on their website, please contact ni.com/ask and ask for the application engineer to send you a copy of NIScanEngine.zip regards Peter Quote
GregG Posted January 13, 2009 Report Posted January 13, 2009 QUOTE (gleichman @ Jan 11 2009, 08:32 PM) Quote I had the same error, but it was fatal for my build. Same solution as yours. What were you using that required that dll? Some scan engine related VI? Did you have real-time installed? I'm trying to figure out how you got into this situation so that perhaps I can fix it. thanks, greg Quote
PeterB Posted January 13, 2009 Author Report Posted January 13, 2009 QUOTE (GregG @ Jan 13 2009, 04:29 AM) Quote What were you using that required that dll? Some scan engine related VI? Did you have real-time installed? I'm trying to figure out how you got into this situation so that perhaps I can fix it.thanks, greg I installed LV v8.6 PDS (under/with a VLA/VLM) and the first time I went to build my application I got the error. I don't have LVRT installed. My local NI app'n engineer told me there is already an associated CAR# but will get it to me later. Greg are you an NI employee ? What is your motivation for fixing the problem e.g. are you experiencing it too ? regards Peter Quote
gleichman Posted January 14, 2009 Report Posted January 14, 2009 QUOTE (GregG @ Jan 12 2009, 12:29 PM) Quote What were you using that required that dll? Some scan engine related VI? Did you have real-time installed? I'm trying to figure out how you got into this situation so that perhaps I can fix it.thanks, greg No LVRT. I have DevSuite installed with LabVIEW 8.6 PDS. I never figured out what the culprit was. I sent code into NI that was causing the problem, but due to some organizational issues on my part the submission was incomplete. By the time I got my code structure fixed, I figured that NI had the problem corrected. What do you mean by scan engine? Quote
GregG Posted January 16, 2009 Report Posted January 16, 2009 QUOTE (PeterB @ Jan 12 2009, 04:24 PM) Quote I installed LV v8.6 PDS (under/with a VLA/VLM) and the first time I went to build my application I got the error. I don't have LVRT installed. My local NI app'n engineer told me there is already an associated CAR# but will get it to me later. Greg are you an NI employee ? What is your motivation for fixing the problem e.g. are you experiencing it too ? regards Peter Yes, I am an NI employee, and I specifically work on the code related to nilvce.dll. thanks for the reply, greg Quote
PeterB Posted January 22, 2009 Author Report Posted January 22, 2009 CAR# 140034 QUOTE (PeterB @ Jan 12 2009, 10:55 AM) Quote This post is to follow up from http://forums.lavag.org/-t11544.html&view=findpost&p=55706' target="_blank">here where I reported that NIScanEngine\nilvce.dll couldn't be found during a build I was attempting. It was a non fatal error as the exe still built.NI gave me a solution by suppyling me with the missing directory and files (zipped up) which you install to here C:\Program Files\National Instruments\LabVIEW 8.6\vi.lib\NIScanEngine\ Unless NI have posted these files on their website, please contact ni.com/ask and ask for the application engineer to send you a copy of NIScanEngine.zip regards Peter Quote
virtualspot Posted April 10, 2009 Report Posted April 10, 2009 I have the missing nilvce.dll error when I use timed loop instead of the while loop. steve QUOTE (GregG @ Jan 15 2009, 08:43 AM) Quote Yes, I am an NI employee, and I specifically work on the code related to nilvce.dll. thanks for the reply, greg Quote
