nitulandia Posted January 15, 2009 Author Report Posted January 15, 2009 General Details: * LV version in use: 8.2.0 * In the code I'm using a few LabVIEW popus. * I'm compiling the code on a "development" machine, and distributing the LV DLLs to "production" PCs. * I have just added a new "production" PC with only the LV RTE installed. Clearly, I'm interested in running LV DLLs, and not the source code. My test scenario is the following: I have a home-made sequencer (similar to TestStand) which loads and runs my LV DLL. The issue I was having is that when I ran my tests on that new "production PC", the LabVIEW popus would always be on the back of my sequencer (not the most front) . In my code, I was using the appropriate properties to enforce that the LV popup would run as the most front. Well, the fix to this was a Windows registry setting: My Computer/HKEY_CURRENT_USER/Control Panel/Desktop/ForegroundLockTimeout (set the value to 0 hex) If you need more details you can find them on the web (google search, etc) For LAVA gurus, are there any other known solutions to the issue I've described? I would rather stay away from making mods to the registry keys. Quote
nitulandia Posted January 15, 2009 Report Posted January 15, 2009 General Details: * LV version in use: 8.2.0 * In the code I'm using a few LabVIEW popups. * I'm compiling the code on a "development" machine, and distributing the LV DLLs to "production" PCs. * I have just added a new "production" PC with only the LV RTE installed. Clearly, I'm interested in running LV DLLs, and not the source code. My test scenario is the following: I have a home-made sequencer (similar to TestStand) which loads and runs my LV DLL. The issue I was having is that when I ran my tests on that new "production PC", the LabVIEW popups would always be on the back of my sequencer (not the most front) . In my code, I was using the appropriate properties to enforce that the LV popup would run as the most front. Well, the fix to this was a Windows registry setting: My Computer/HKEY_CURRENT_USER/Control Panel/Desktop/ForegroundLockTimeout (set the value to 0 hex) If you need more details you can find them on the web (google search, etc) For LAVA gurus, are there any other known solutions to the issue I've described? I would rather stay away from making mods to the registry keys. Quote
crelf Posted January 15, 2009 Report Posted January 15, 2009 QUOTE (nitulandia @ Jan 14 2009, 03:56 PM) For LAVA gurus, are there any other known solutions to the issue I've described? I would rather stay away from making mods to the registry keys. You can set the z-order to HWND_TOPMOST using user32.dll: Quote
nitulandia Posted January 16, 2009 Author Report Posted January 16, 2009 QUOTE (crelf @ Jan 14 2009, 03:07 PM) You can set the z-order to HWND_TOPMOST using user32.dll: Hello Crelf, I modified my windows registry, and put the default value back (not zero). Then I tried your suggestion, and in my case it did not make a difference, the pop-up was still shown running on the back of my sequencer. I've tried several things: if I set the VI properties/window appearance to be shown when loaded this works. The issue here is that the entire VI front panel is brought to the front, this is not the behavior I'm after, I only want the pop-up shown. Regardless, thank you for the suggestion. Quote
crelf Posted January 16, 2009 Report Posted January 16, 2009 QUOTE (nitulandia @ Jan 15 2009, 10:09 AM) The issue here is that the entire VI front panel is brought to the front, this is not the behavior I'm after, I only want the pop-up shown. Do you know what the pop-up window's title is? If so, use it. If not, try to find what the hWnd is. Quote
nitulandia Posted January 16, 2009 Author Report Posted January 16, 2009 QUOTE (crelf @ Jan 15 2009, 10:29 AM) Do you know what the pop-up window's title is? If so, use it. If not, try to find what the hWnd is. The pop-up name is "Three button dialog.vi" This VI is part of the LV library, under the "Dialog & User Interface palette". I'm still seeing the same behavior. As mentioned previously, this is not a show stopper. This is the microsoft article that led me to the registry solution: http://support.microsoft.com/kb/886217 Quote
