need help
harika
i'm developing one GUI for motion controller.I'm using serial communication as sub vi,so that i can send packet format for each control.but ,after running main vi and selecting any control,the corresponding data is transmitted and it is strucked.I want vi without opening front panel of serial communication and data has to be transmitted for each n every control.It is for pc to pc communication.
The vi is attached hare.
Thanking you,
Harika pothu.
  • 1 month later...
Hello Harika,
Project sounds neat but we need a little more info before proceeding:
(1) Could you attach the 'Advanced Serial Read and Write" VI w/all subvis
(2) Could you explain with more detail the intentions of your code? We can help but need more specifics.
I see an opportunity to help but need a little more info first. Also, maybe work on the grammar a bit :)
Thanks,
Justin
