Message timing
rom76
Dear members of the forum,
I faced a problemm where i need for example to register the time of outgoing message as well incoming messages, What is the method that can be used to accomplish this task? Thank you in advance for all your help.
Regards,R
QUOTE (rom76 @ Feb 10 2009, 06:30 AM)
Regards,R
Well there are lots of ways. There is a timestamp data type which can be bound in a cluster to whatever data type you are using for your messages. If that's not help enough, maybe you can post your code and tell us what's not working.
QUOTE (jdunham @ Feb 10 2009, 09:22 PM)
Thank you , I will try that and will post the code.
Dear friend, here is the code, I didn't really get what you meant, I checked out different time stampdata functions but didn't find the one that could be used here. i need to measure the time when the meassage leaves string nad when it comes to string 3. Thank you aginn for your help,very nice of you.
QUOTE (rom76 @ Feb 11 2009, 03:02 PM)
Replace your GetDateTime function with the Tick Count(ms) function found in the same pallette. This should solve your problem.
Justin Thomas
QUOTE (JustinThomas @ Feb 11 2009, 01:55 PM)
Justin Thomas
Thankks Justin, I will try that.
