Tortoise SVN Diff using LVMerge
Hey everyone,
I was able to use:
http://expressionflow.com/2007/08/28/using...th-tortoisesvn/
and integrated SVN with the merge command, and it works great!
What about using the Diff command from Tortoise SVN Windows client?
I've googled around a bit and found an application called 'lvdiff', but I haven't seen any recent activity on the project since 2005.
Has LVMerge replaced lvdiff?
If so, has anyone figured out how to configure Tortoise to use LVMerge when attempting to diff a vi?
Thanks!
-ben
QUOTE (Paul_at_Lowell @ Feb 19 2009, 11:44 AM)
This thread New Software Engineering and LabVIEW Wiki links to pages that have detailed instructions on how to set up TortoiseSVN to use lvdiff.
Paul
Excellent!
I was through those links in the past, but I suppose I did not dig deep enough :-).
A shortcut:
http://wiki.lavag.org/Set_up_differencing_capabilities
Just tried it out with 8.6.1, everything works great!
-ben
  • 3 weeks later...
The LVDiff works well for simple VIs. One problem I am currently unable to solve is how to Diff VI's which have SubVIs. If using LVDiff with VIs having subvis in the repository LabVIEW would give me the Browse for VI option.
I want the working copy VI to use SubVIs from the working copy and the repository VI to use SubVIs from the repository.
Is this possible?
Justin Thomas
