JustinThomas Posted February 25, 2009 Report Share Posted February 25, 2009 I would like to sample my data based on an external clock on a FPGA board. I was thinking of using a timed loop with a DI line as external clock. The timed loop with iterate based on the clock rate of this DI line. I have not found any way of doing this. Is this possible? or am I looking down the wrong path? Any alternate suggestions would be most welcome Regards, Justin Thomas Quote Link to comment
alexwarrior Posted March 18, 2009 Report Share Posted March 18, 2009 Hi Justin, Can you explain a little more about what hardware you're using? I.e. what LabVIEW is running on, what FPGA, any other DAQ hardware you're using, etc. Best, - Alex Quote Link to comment
JustinThomas Posted March 19, 2009 Author Report Share Posted March 19, 2009 QUOTE (alexwarrior @ Mar 17 2009, 10:26 AM) Hi Justin,Can you explain a little more about what hardware you're using? I.e. what LabVIEW is running on, what FPGA, any other DAQ hardware you're using, etc. Best, - Alex I am using a 7811R board. My requirement is to read a digital data line at the rising edge of a digital clock line. The problem is the clock line is external and may vary. The requirement is similar to sampling on a DAQ board using an external clock. Quote Link to comment
