MBeckford Posted March 8, 2009 Report Posted March 8, 2009 A set from a set of sampled data from a thickness sensor. The samples are stored in an appropriate array of up to 100 elements. The values represent the depth of the insulation around a particular cable. The thickness can vary from 0-4mm represented by a corresponding real value stored in the array. as long as the depth is between 1 and 4 mm the cable falls within the allowable specification however if it falls below 1mm it is deemed to be too thin. Design a VI that will identify the number of thin values and display as a percentage of total number of samples. The front panel have the must have the following: An array of controls holding the sampled values. An indicator holding the percentage of thin values. Labview version 8.2 Quote
