Network Shared Variables with RT FIFO
viSci
The Good News: It is possible to set the initial value of a NSV on an RT target.
The Bad News: There does not seem to be anyway to determine when this initial value is available from the SV server.
For some reason there an initializing period of time that the PSP client (your RT application) needs to connect to the SV server to obtain the
current value of a NSV. You can try looping until the warning message
(Warning -1950679027 occurred at an unidentified location
Possible reason(s):
LabVIEW: (Hex 0x8BBB000D) NI-PSP has not connected to the server yet)
goes away but this does not alway guarantee that the next transaction will be good.
I think NI should provide a utility that can be called that forces this
initialization process to occur.
