"Select Object from Type Library" dialog takes too long to load
When I place a property node, right-click it, and go to Select Class >> ActiveX >> Browse..., or do anything else to open that same dialog, it has to take at least a minute before the dialog opens. Is there any way to make this shorter? I have 768MB of RAM (upgraded from 192MB!) in case that matters.
QUOTE (flarn2006 @ Apr 10 2009, 12:31 AM)
With 2GB of RAM and a 2GHz processor, my initial attempt to open the Browse dialog took about 60 seconds. But after that (even after restarting LabVIEW) it takes about a second. Do you have an obscene number of ActiveX controls installed or do they change often? CPU probably plays a bigger role in this than RAM.
