newbie to waveform graph
ccie
Hi all , i have successfully displayed a full wave rectifier on labview waveform graph via a serial port thRough a microcotroller , but when i turn off supply to the rectifier i expect the rectifer output to be removed from the labview waveform graph but it still gets displayed , why is it so ? and is there any way to make the waveform change in real time.
find the attached VI
QUOTE (ccie @ Apr 12 2009, 06:52 PM)
  Quote
when you remove the rectifer output, no byte is to be read! your waveform couldn't be refurbished, so it's still display as before.
QUOTE (confidence @ Apr 13 2009, 01:36 AM)
  Quote
Thanks confidence and downloaders,
So labview does display what ever bytes it receives in real time ? [yes|no] , the reason for asking this is cos i need to know where the problem lies(either in ucontroller program or labview)
I am really new to labview , pls can anyone modify my code to display nothing if no bytes exist at the serial port and upload.
Thanks
Love
Zinedine.
QUOTE (ccie @ Apr 14 2009, 11:56 PM)
  Quote
Thanks
Love
Zinedine.
you may be not understand what i said clearly, now i have changed your program here.
