Ready/write any format file as binary format
Dear,
I think we can store any format file as binary in db. So I have a trial to read a .zip file as binary, and then convert binary array to a string, which I'll save into db in another vi.
Why don't I use Byte Array To String.vi to convert binary array to string? Because many characters are not alphanumeric, which can't be recognized by DB.
My question is, why I can't open the new created .zip file?
Please see the picture below, I'm confused very much, data 1 are absolutely same as data 2.
Please copy 1.zip to c:\ while you help me debug the vi.
QUOTE (labc @ Apr 14 2009, 08:16 AM)
  Quote
The data 1 might be equal to data 2 in terms of values, but the representation is different.
Notice the red dot when you write data to the data 2 terminal, this dot represents a coercion, i.e. a conversion between one representation to another.
I have not opened the code, but my guess is that when you write data to the new zip file, you are actually writing data as I32 values, not U8.
The solution would be to specify the data type when you are converting from string to numeric.
/J
QUOTE (JFM @ Apr 14 2009, 09:15 AM)
  Quote
/J
JFM,
You're right, It works after adding one "To Unsigned Byte Integer.vi". Thank you.
Labc
