How can I pass specific cluster(struct) to my c++ application from
Hi All;
I have a separated projects in c++ and labview and which have to share dynamically created data each other. I have tried socket usage on UDP and can send string data via socket from Labview to c++ app. But I don't know how can I pass cluster (in c++ struct) data from labview.
Could anyone show me or give me any reference about kind of these operations to make me achieve?
Thanks in advance.
Umit Uzun
QUOTE (Umit Uzun @ Apr 21 2009, 02:44 AM)
Hi All;
Thanks in advance.
Umit Uzun
Use the LabVIEW "Flatten to String" function - this will serialize a LabVIEW data cluster into a byte stream that can then be unpacked by the C++ app into a C++ struct - for example
LabVIEW cluster: Numeric (Double), Numeric (U32 Int), Array (U16) (note that this must be a populated array of the same size as the target struct)
to pass this to a struct of
struct LVData
double x;
int y;
short array[100];
Then just wire the cluster up to flatten to string (wire a false constant into the "prepend array or string size? " control) and then pass the flattened string to your C++ app. Now that app will have to deserialize into a struct.
Mark
QUOTE (mesmith @ Apr 21 2009, 03:40 PM)
struct LVData
double x;
int y;
short array[100];
Mark
Hi Mark;
Thanks so much. I have resolved the problem with your awesome directions :thumbup:
Best Regards.
Umit Uzun
You could also serialize the cluster using XML (JKI's EasyXML does serialize clusters well), which might make deserialization on the C++ side more straightforward. This is supposedly a common application of XML.
