manojba Posted April 25, 2009 Report Posted April 25, 2009 Hi, I just wanted to know is it possible to change the title in title bar other than the vi's name I just want the name and not ".vi" at the end thanks in advance... Quote
Prabhu_V Posted April 25, 2009 Report Posted April 25, 2009 Go to Files>VI Properties>Window Appearance .. Edit the Window title to the name you require. Quote
Mark Yedinak Posted April 25, 2009 Report Posted April 25, 2009 QUOTE (Prabhu_V @ Apr 24 2009, 01:05 AM) Go to Files>VI Properties>Window Appearance .. Edit the Window title to the name you require. You can also do this programmatically using a property node. Quote
