Error from "Set Control Value {Variant}__ogtk.vi"
This thread was manually moved from OpenG to LAVA.
Hi openG users,
Since LV2010, Set Control Value {Variant}__ogtk.vi function end on error for some control type like cluster reference.
See SetControlValueBug-LV2009.vi in attachment to reproduce the bug.
LV2009 SP1 --> OK
LV2010 or later (SP1 and LV2011 beta) --> NOK
To fixe the bug, you just need to replace Ctrl Val.Set Invoke Method by Ctrl Val.Set (variant) Invoke Method.
See Set Control Value {Variant}__ogtk--fix.vi in attachment to fix the issue.
It will be great if this fix could be added to oglib_appcontrol.
Thanks,
Olivier
Set Control Value Variant__ogtk--fix.vi
  • 4 months later...
