Generate a analogue Signal with the HBM MX 878
Fritz_85
Hello everybody,
since I yesterday I have to work with a HBM MX878 Analogue-Out device, which is able to generate
analogue signals.
I have been trying to program a Labview VI which is able to generate a analogue signal
with the MX878, but I just have no idea how to realize it.
Maybe somebody who has already worked with MX878 could send me a little Test VI,
which is able to generate a analogue signals.
I would really appreciate any kind of help or advice, since it is very urgent for me to solve that problem!!!
Thank you in advance!
Fritz_85
Hi Saverio,
Thank you for your reply.
I know that HBM provides LabVIEW Drivers. I have already programmed a VI for the DAQ of the MX 840. However,
I want to generate a analogue signal with the MX 878 and I don't know which VIs to use, from the HBM LabVIEW Drivers,
to programm a VI which makes the MX878 generate an analogue signal.
Maybe it also possible to realize it with the regular Labview VIs. I just need some advice how to start!?
I thought maybe with the TCP/IP VIs from LabVIEW, since I am communicating with the MX878 by Ethernet.
Do you have experience with the MX878?
