Can I Get A Build's Version Number Programmatically?
Thanks for the upload. I went ahead and set up a build, modified your example to grab everything from the Verison info node, and pushed it into a cluster...
I must say that I had been doing this exact same thing the other day, but it was not returning the same strings I see here. Unless I was smoking crack.
[EDIT]
Actually, it looks like "Fix" and "Build" map to ProductBuildPart and ProductPrivatePart respectively; which may have given me trouble
[/EDIT]
Thank you!
post-143-1241120737.png?width=400
post-143-1241120639.png?width=400
post-143-1241120650.png?width=400
  • 2 weeks later...
  • 2 weeks later...
