defining a llb file inside of a case structure (invoke node)
Hello everyone,
I am trying to evaluate a temperature sensor.To do that I have to monitor thermocouple readings.Thermocouple is connected to FP-TC-120 temperature module. Besides, I have to acquire data from an optical spectrum analyzer. I am using 3650.VI to monitor the temperature and 86140B Trace_Screen Capture(2).llb o trace the data from the OSA.
I am trying to use Invoke Node VI to trace data from spectrum analyzer. To do that I specified the necessary file path as an input to the code. The problem is the necessary VI (Write Trace to File.VI) is inside of a llb. file and needs other codes to completely function.
That's when I run the code, (and when the stability condition is met) the computer asks me to save the spectrum analyzer data to a file called trace.csv. When I press ok, it just saves an empty file with a header (Power(dbm) Wavelength (nm)). Apparently it works parallely with other VI. How can I make use of the VIs inside of a .llb file with invoke node VI or should I use other VI to do combine temperature monitor VI with data tracing VI.
The second problem is with the stability criterion of temperature.In the attached VI, I check whether the thermocouple reading stays within 0.8 degree stability range for 900 seconds. I want to change this. I
want to check the stability of the temperature by comparing the final data with the previous ones. Is there any specific VI that should be exploited to check the fluctuations of waveforms?
Thanks a lot
QUOTE (deniz @ May 1 2009, 10:14 AM)
Hello everyone,
Thanks a lot
The LLB is simply an additional hierarchy level in the path to the VI and has absolutely nothing to do with your problem here. You have some problem in how you call those VIs and/or when, but the fact that it is in an LLB changes nothing, except maybe if the VI assumes internally that it can write to a file in the same directory as where it resides itself, but from what you describe it is not clear if that might be a problem here.
I also don't understand why you are using the Invoke Node instead of just simply putting the icon into the diagram.
Usually condensing down everything into a simple example that you can upload here will help much more than 10 pages of hard to understand explanations of what you think you might be doing.
Rolf Kalbermatter
