Highlander Posted May 7, 2009 Report Posted May 7, 2009 Hi All, I am attempting to control the TI Code Composer Studio V3.3 with LabVIEW, I have managed to open the programme with the System Exec.VI Would anyone have any experience in using this software via the command line? If so would you be able to provide a list of the command codes? Hope you can help? H Quote
dannyt Posted May 14, 2009 Report Posted May 14, 2009 QUOTE (Highlander @ May 6 2009, 09:29 AM) Hi All,I am attempting to control the TI Code Composer Studio V3.3 with LabVIEW, I have managed to open the programme with the System Exec.VI Would anyone have any experience in using this software via the command line? If so would you be able to provide a list of the command codes? Hope you can help? H Hi Not totally sure how helpful this reply will be but you might want to look at the Code Composer Scripting Add on CCS (CCS_Scripting_Com.dll), we are currently using this (not without the odd problem) on our production line to program up our Flash within a LabVIEW test system. Below are some of the few links I can find about it they tend to use Perl or VB but same principle holds for LabVIEW link1 link2 link3 You could also try and get more information from TI support. EDIT -- updated -- I was looking around and just managed to find on the NI site a download of their "no longer supported" DSP Toolkit though it look written in LabVIEW 7 I have manage to install it into LabVIEW 8.2.1, about five minutes ago, so it might be worth looking at. Quote
