Subversion svn checkout vs. update
In the little bit of testing that I have done, it seems that when svn checkout is run on a pre-existing working copy it acts just like svn update. I can't find any "official" reference to this in the manual or googling.
Can anyone confirm or dispute this claim? The only difference I see is that svn checkout requires an explicit URL?
I am in a situation where I would like TestStand to pull the latest files from a subversion repository before each test begins. If calling svn checkout will not cause any problems then it greatly reduces the code I have to write. I can do one simple "checkout" which will either checkout or update depending on the state of the build tree (I don't have to try to figure out if a working copy already exists).
Thanks,
Toby
I tested by checking out a repository one revision back, then checking out again with the same target and no revision specified - it was, in fact, smart enough to update the working copy instead of re-checking out everything.
QUOTE (asbo @ May 15 2009, 10:56 AM)
Thanks. That's what my testing showed too, so I guess I'll go with the checkout command to simplify my code unless I hear about or discover a good reason not to do it that way.
