LAVA 1.0 Content Posted June 5, 2009 Report Share Posted June 5, 2009 is there a way to clear the display using a reset button? Many Thanks Quote Link to comment
Darren Posted June 5, 2009 Report Share Posted June 5, 2009 Try using a Case Structure...if the reset button is pressed, wire an empty string to the display (and into your feedback node). Otherwise wire in the string you're keeping in the feedback node. -D Quote Link to comment
LAVA 1.0 Content Posted June 5, 2009 Author Report Share Posted June 5, 2009 QUOTE (Darren @ Jun 4 2009, 11:54 AM) Try using a Case Structure...if the reset button is pressed, wire an empty string to the display (and into your feedback node). Otherwise wire in the string you're keeping in the feedback node.-D Thanks alot Quote Link to comment
