Ton Plomp Posted July 3, 2009 Report Posted July 3, 2009 Name: Variant to Control Submitter: Ton Plomp Submitted: 03 Jul 2009 File Updated: 21 Sep 2009 Category: General Version: 1.1.0 LabVIEW Version: 8.2 License Type: BSD (Most common) opyright © 2007, Ton Plomp All rights reserved. Author: Ton Plomp --see readme file for contact information Description:: This tool converts any datatype into a control, this control can be typedef, a special Use-case VI is added: Array of strings to an enum. Especial usefull if a list of allowed values is avialable and is case sensitive (XML...) The control can be saved as a typedef Originated from Array To Enum Acknowledgements: Uses code by Bob Billier from his RTM to Enum tool Dependencies: Uses the following OpenG toolkits: oglib_lvdata-2.7-1 oglib_error-2.3-1 oglib_file-2.8-1 These can be installed with VIPM (http://jkisoft.com/VIPM) Version History: 1.1.0: Added Variant to control 1.0.0: Initial release of the code. Click here to download this file Quote
