klessm1 Posted July 4, 2009 Report Share Posted July 4, 2009 I am running into some problems outputing an analog output sine wave with my DAQ using the onboard sampleclock. At one point I was able to get the vi running quite well and repeatable. When revisited however, I started seeing error that the driver could not provide the device with the points fast enough. I was running the sampling rate at 250k for a 1k tone, but I seem to only be able to get about 20k sampling rate. This creates a fairly choppy signal expecially when the frequency is bumped up to 8k. I am only producing 1 second of data. See attached bmp. The I/O references passed in are channels not tasks. Could this be the problem? I'm a little frustrated as this should be a very simple vi to create and I am having all kinds of trouble with it. Quote Link to comment
Ton Plomp Posted July 6, 2009 Report Share Posted July 6, 2009 I am running into some problems outputing an analog output sine wave with my DAQ using the onboard sampleclock. At one point I was able to get the vi running quite well and repeatable. When revisited however, I started seeing error that the driver could not provide the device with the points fast enough. I was running the sampling rate at 250k for a 1k tone, but I seem to only be able to get about 20k sampling rate. This creates a fairly choppy signal expecially when the frequency is bumped up to 8k. I am only producing 1 second of data. See attached bmp. The I/O references passed in are channels not tasks. Could this be the problem? I'm a little frustrated as this should be a very simple vi to create and I am having all kinds of trouble with it. Well if you have a look at the provided examples they all start with creating a task, this is a very good habit. So yes I would try such a thing. Ton Quote Link to comment
klessm1 Posted July 6, 2009 Author Report Share Posted July 6, 2009 Well if you have a look at the provided examples they all start with creating a task, this is a very good habit. So yes I would try such a thing. Ton Most of the analog output examples I have seen create a channel not a task. Usually the task is created after calling the timing or other DAQmx function. I am looking at the example "Cont Gen Voltage Wfm-Int Clk-Non Regeneration.vi" and it has the same issue as what I am seeing. If you have too fast of a sample clock rate (over the 20k) then it gives the same error depending on the speed of the PC. I have been looking into using DMA instead of interrupts and it seems to work a little better. I have attached the error screen...I forgot it in my original post. Thanks Quote Link to comment
