Francois Normandin Posted July 4, 2009 Report Posted July 4, 2009 Name: Password_class Submitter: LAVA 1.0 Content Submitted: 04 Jul 2009 Category: LabVIEW OOP LabVIEW Version: 8.5 Version: 1.1.0 License Type: BSD (Most common) Potentially make this available on the VI Package Network?: Undecided Copyright © 2008, François Normandin All rights reserved. Author: François Normandin -- see readme file for contact information website: www.monpapyrus.net/LabVIEW/index.html Description: Class for management of password objects. The object contains a MD5 encrypted password. Methods are of two types depending on source of password. From non-encrypted or encrypted sources. All vis are documented. There is an example VI that shows how to use encrypted & non-encrypted versions. Encryption level provides a mean to recursively encrypt many times over, resulting in better security against rainbow tables attack. Initialize once with Password_Create method. [Non-encrypted source] Source is from a dialog box or equivalent. The password is not encrypted at the moment the object is created. Password_Create method will create a new object, encrypt the password and store it. [Encrypted source] Source is from a file or tcp-ip connection. The password is already encrypted at the moment the object is created. Password_CreateEncrypted method will create a new object and store the password. Dependencies: Uses the following OpenG toolkits: oglib_md5-1.6-1 GOOP3® OpenG: <http://wiki.openg.org/Main_Page> GOOP® Community Edition 2.5: <http://www.endevo.se> Change Log: 1.0.0: Initial release of the code. 1.0.1: Readme modifications 1.1.0: Added encryption level and modified naming convention for dynamically accessible methods. Click here to download this file Quote
