Incorporate Matlab DLL in LabVIEW
Hello everybody,
I´d like to incorporate a DLL created with Matlab in LabVIEW to develop a communication between them. I´m trying a example from the labview forums (HOW TO GENERATE A DLL FROM A MATLAB FUNCTION SCRIPT TO RUN IN LABVIEW) but it doesn´t work because the dll always return me -1 of the function caller of "mclInitializaApplication". I´ve found that the problem is with the initialization of instance "mcl" of matlab.
I´ve done the C Shared library Example from Matlab help and they work fine.
I´ve attached the the code and document which I used to write my code and to compile it.
Thank you very much
Regards
dllmatlablabview.pdf
dll_labview.zip
Somebody can help me!!
Thanks
Regards
Hello everybody,
Thank you very much
Regards
