WireJunky Posted July 8, 2009 Report Share Posted July 8, 2009 We were using VSS but have since moved to TFS now. Is there a way to use TFS in LabVIEW like I did with VSS. I was able to connect to VSS and check-in/out code inside of VSS, however with TFS I have to use the client in Visual Studio 2008 to check in/out code. Thanks, Matt K. Link to comment
gmart Posted July 8, 2009 Report Share Posted July 8, 2009 We were using VSS but have since moved to TFS now. Is there a way to use TFS in LabVIEW like I did with VSS. I was able to connect to VSS and check-in/out code inside of VSS, however with TFS I have to use the client in Visual Studio 2008 to check in/out code. Thanks, Matt K. I believe you need to install an integration plugin. See this Microsoft KB - http://www.microsoft.com/downloads/details.aspx?familyid=87E1FFBD-A484-4C3A-8776-D560AB1E6198&displaylang=en Link to comment
Please sign in to comment
Sign In Now
