WireJunky Posted July 8, 2009 Report Posted July 8, 2009 We were using VSS but have since moved to TFS now. Is there a way to use TFS in LabVIEW like I did with VSS. I was able to connect to VSS and check-in/out code inside of VSS, however with TFS I have to use the client in Visual Studio 2008 to check in/out code. Thanks, Matt K. Quote
gmart Posted July 8, 2009 Report Posted July 8, 2009 We were using VSS but have since moved to TFS now. Is there a way to use TFS in LabVIEW like I did with VSS. I was able to connect to VSS and check-in/out code inside of VSS, however with TFS I have to use the client in Visual Studio 2008 to check in/out code. Thanks, Matt K. I believe you need to install an integration plugin. See this Microsoft KB - http://www.microsoft.com/downloads/details.aspx?familyid=87E1FFBD-A484-4C3A-8776-D560AB1E6198&displaylang=en Quote
