TomasAa Posted July 13, 2009 Report Posted July 13, 2009 Hello everyone, I'm trying to change the machine access list for a VI-server in run (programmatically). I can add clients in run without any problems, but i cant remove clients without restarting the TCP-listener witch would cause all clients connected to get a timeout. Anyone know a way around this? LabVIEW 8.6 (windows and linux) Thanks, Tomas Quote
Tim_S Posted July 14, 2009 Report Posted July 14, 2009 I'm trying to change the machine access list for a VI-server in run (programmatically). I can add clients in run without any problems, but i cant remove clients without restarting the TCP-listener witch would cause all clients connected to get a timeout. Anyone know a way around this? I've not tried this, but it seems that you may want to perform access such as this programmaticly. You should be able to use the remote address and an internal lookup table to do what you want. Tim Quote
