Flattern to XML - rounding
Hi all,
My problem with Flattern to XML is rounding, see following example.
DBL 0.123456789
result:
<DBL>
<Name>Value</Name>
<Val>0.12346</Val>
</DBL>
Is there any way to set precision of conversion? BTW conversion back (unflattern) works just fine.
Thanks&Regards,
David
  On 7/15/2009 at 9:55 AM, DaveX said:
Hi all,
DBL 0.123456789
result:
<DBL>
<Name>Value</Name>
<Val>0.12346</Val>
</DBL>
Thanks&Regards,
David
I just tried this on my system (LV 8.6.1) and passed a double control into the Flatten To XML function and got
<DBL>
<Name>Value</Name>
<Val>0.12345678900000</Val>
</DBL>
which preserves the precision of the double - In LV 8.5.1 I get the results you describe. I thought I remembered something about Flatten To XML having some bugs fixed lately. So, if you can, upgrade to 8.6 ;)
Mark
