Some Help Needed
i currently have this query vi which will display data which i have query. im using labview 8.5 and ms access as my database. There seems to be some problem with my vi. Everytime i change something in my vi, there will be an error with my database variant. when that occurs, i will have to change my datatype to numeric constant before changing it back to string constant before i can run the vi. also, the data which i query will be display in column view instead of the usual row view. my sql code is derived by my ms access so i believe the error comes from my vi.
15-7-09db.vi
